I just burned a copy of the Charlie Brown Halloween DVD to CD-R. I notice that unlike the DVD where you can jump to the next chapter if you want to skip a section, on the VCD its one 25 minute segmnt that has to be fast forwarded to get to a certain scene like a VHS tape. My question is can a VCD support chapters? If so is this done during the ripping process or something that has to be done later.
It can be done, but it's a bitch. You'll spend more time doing that than the DVD rip.
Sometimes the DVD player itself will have an option: 'Goto', then you select the time you want to go to. It's sometimes labled 'scene'.
Hope that helps. -
Its something that has to be done during authoring. vcdimger, video pack 4.0, or I-Author can do it. Its not hard at all to do and it doesnt take very long at all. Using I-author I create chapters including a chapter selection menu in about 1 min.
In the AUTHOR section of this site there are some guides explaining how to implement chapters in your vcds. -
DVDx can create several files of certain size each one that you can use as chapters and quick skip. That is the way I use it, when you play it back it is seemless. I burn it using Nero and create the menu so I can jump to a scene as well.
That would be the easiest way I think.
Alfonso -
http://www.personal.psu.edu/users/r/d/rdm186/
its really easy...
thats a full guide....motion menus are harder....stills are CAKE!!
1
marty
Burning VOB files to DVD WITHOUT Menus Or Chapters
By mediachimp in forum Authoring (DVD)Replies: 5Last Post: 11th Aug 2010, 02:11 -
Burning a dvd so that it keeps the orignal menus/chapters..
By Dchristy47 in forum Newbie / General discussionsReplies: 3Last Post: 29th Jul 2010, 03:11 -
Preview bluray/avchd dvd menus,chapters
By vandaLo in forum Newbie / General discussionsReplies: 1Last Post: 21st May 2010, 14:55 -
Two Different Concert In One DVD with menus, chapters, play all Functions.
By madman1987 in forum Authoring (DVD)Replies: 4Last Post: 21st Dec 2008, 20:17 -
Episodes from Several DVD's Onto One With Menus and Chapters
By Savutay in forum Authoring (DVD)Replies: 0Last Post: 12th Oct 2007, 16:41
