I'm planning on backing up my VHS tapes (both taped off-the-air and commercial tapes) to DVD-R using a DVD recorder.
Is it "worth" it to buy a S-VHS VCR just for this or will my current VCR be okay?
P.S. I know I will have to buy a device to handle the Macrovision on the commercial tapes.
Thanks in advance.
Results 1 to 30 of 36
I bought this JVC VCR which has a time base corrector and active video calibration and trust me it makes a big difference compared to the low cost junk we buy at WalMart. It was only $149 and was delivered in one day. It has s-video out on the back and the front FYI.
http://www.ecost.com/ecost/shop/detail.asp?action=detail&dpno=291073#scroll -
Did S-VHS give better quality even if the tapes were originally recorded on a standard VCR (non-S-VHS)?
You get S-Video out on an SVHS machine....one more selling point.
A good quality vhs deck will not be surpassed by an svhs machine playing vhs.
On many dvd recorders the composite input splits the signal y/c just the same as svhs input does. -
Bob W is correct the TBC makes all the difference in the world. I have two JVC 9500's and have transferred many old VHS tapes with them. They cleanup picture problems very well.
If your transferring VHS tapes a TBC is a must have option. -
Originally Posted by Bob W
hi broadway,
before investing in expensive toyI would first continue as you were w/
capturing from these devices w/ your VCR.
But, my recommendation would be to just get a decent S-VHS deck, like
those by JVC. I have a JVC S-VHS HR-S3910U w/ S-Video in/out.
IMO, this unit output pretty good quality. Doesn't have one of those TBC's
built-in though, but that's ok, becuase:
* A, most of my VHS are either in good or great shape, and
* B, I already have a stand-alone model, the TBC-100 +/- $250
But, since you have yet to have issues w/ your VHS transfer projects, I
would not start you off w/ spending $$$.$$ dollars. You probably haven't
even started yetand we're all pushing to to send hehe.. Anyways..
If cash is an issue, then find a good S-VHS and start w/ that.
Also, (and very important) we dont' know what you skill level is. You could
be a complete novice to all this, and if we start pushing you w/ all these
weird gizmo's, that's just gonna add to the nonense
Important things. . .
* mobo and capture card (must work in concert w/out issues)
* Good capture card, but minal is ok, provided system stability and OS.
* No IRQ or other issues
* VCR - good brand S-VHS w/ S-Video in/out (min. w/ an OUT)
* Your Source tapes. Best condition, not aged and word w/ multi playing time
...and should have ben recorded in SP mode.
* User skills level - known processes and techniques (from VHS to DVDR)
* Ability to work alone
* other stuff her, but I'm pretyt worned out today, plus I'm making dinner.
From the Video Workstation of,
-vhelp 2075 -
The built-in TBC and stand-alone TBC do different things. I have both for that very reason.
vhelp, that comment about ability to work alone really struck a funny bone.
anyhow, "vhelp" is right.
I haven't begun this adventure yet.
I like to do my research up front. Not one for experimenting.
so, are there any issues I should know about with putting an external TBC in series with the JVC S-VHS which has the internal TBC?
this project is turning to be more and more a money pit
To buy a brand new one here is a link:
http://www.bhphotovideo.com/bnh/controller/home?O=NavBar&A=getItemDetail&Q=&sku=242445...#goto_itemInfo
Granted the price tag is $269.95 but it is cheaper than the consumer based 9000 series by JVC and this unit is actually an industrial model so that plus the fact that it has a TBC makes the price pretty reasonable if you ask me.
These "professional" units from JVC and Panasonic are just consumer models with grounded AC line cords and BNC connectors with a higher price tag as compaired with the consumer model.
Been that way for the last 20 years and hasn't changed!
BTW, I have been using SVHS for the last 12 years for time shifting and archiving. -
Well the link I provided in my last post above was for the JVC SR-V10U S-VHS VCR which is a "professional" unit. The price at B&H is $269.95 and it seems to be very similiar to the "consumer" 9000 series in that it has a buit-in TBC and DNR and adaptive picture control, flying erase heads and blah blah blah.
The description at B&H doesn't tell you much. I got more info on it by downloading the manual from the JVC website.
It seems that the "consumer" 9000 series might actually have a couple more features not present on the SR-V10U but they are a mightly close match and the SR-V10U is $90 cheaper than the HRS-9911 S-VHS VCR
Does the SR-V10U have a tuner? Many of the older "pro: versions didn't.
Originally Posted by videobruce
If you are interested in it go to the JVC website and download the PDF manual. Much more info there than on the B&H website. Plus I think the B&H website claims it has no cable box control or something like that but according to the manual it does.
Originally Posted by lordsmurfPinnacle Studio 8 and DV home video editing (ver.9 already home)
Originally Posted by broadway"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
I have a question for all you S-VHS experts (I'm looking at YOU, lordsmurf!
). Since we're on the S-VHS subject, the unit linked to above has this as a feature:
"Super VHS ET Recording: JVC's breakthrough Super VHS ET (Expansion Technology) eliminates the need to use exclusive, hard-to-find tapes for Super VHS recording. Now you can record high-resolution Super VHS signals on the ordinary VHS tapes you can find in any store. "
Is there anything to this, or is it basically just marketing pap?
Thanks. -
hi thinkert,
my JVC S-VHS HR-S3910U has this feature Super VHS ET plug n play
nonsense, but to be honest w/ you, it's more hype than reality. If you got a
S-VHS unit, USE the SVHS tapes for it.. and not depend on "simulation"
techniques - - otherwise known as "nonsense"
-vhelp 2084 -
Originally Posted by thinkert
Anyways I don't know if the S-VHS ET thing simply does that (allows S-VHS recording on a VHS tape) or if it actually tries to do more i.e., somehow "adjust" the recording knowing that it is putting a S-VHS signal on a VHS tape.
The down and dirty gritty details ... I've tried it and S-VHS ET does appear to have all the picture qualities of S-VHS but the trade off is that the picture is very grainy. So yes you get the benefits of the higher resolution and less color bleed etc. but at the expense of grain.
In short I don't like it. If you want the quality you are gonna have to "bite-the-bullet" and buy S-VHS blank tapes.
S-VHS blanks can be expensive ... especially when you buy then in a retail store (and very few carry them) but on-line you can get them down to around $3.50 to $4.00 whereas the last time I bought a 2 pack at BEST BUY it was like $12 or $13 total for the 2 pack of T-120 S-VHS blanks.
- John "FulciLives" Coleman
P.S.
I had my first S-VHS VCR back around 1994 ... long before the ET thing ... but I never did the drill hole trick myself. A few people reported having problems with that ... loose plastic shards either getting into the tape case and scratching the tape or worse yet lodging inside the VCR and causing all kinds of havoc SO I never tried it."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
I use ET mode on TDK EHG tapes and JVC broadcast VHS tapes, and it's fine for ¼th the cost. Resolution about 300x480, close to broadcast res.
Thanks, vhelp, lordsmurf, FulciLives for your answers. I appreciate it.
ThinkerT -
The JVC HRS9000 line are professional units.
"Industrial" means it's used in surveillance, often in places like banks. Cameras in ATMs, etc.
"Professional" means it's used for video playback application, often in a cable company of small studio settings.
Trust me... I've seen several small studios... and a JVC 9800 is far better than the "pro" rack-mounted machines I'd seen. My first studio visit I expected cool toys, but left thinking "that's it?"Want my help? Ask here! (not via PM!)
One more question that I wasn't able to find an answer for with a quick search on the web: Do S-VHS tapes degrade at the same rate as standard or high-quality VHS, or are they more resistant to degrading, with their higher density?
Thanks. -
Originally Posted by thinkertWant my help? Ask here! (not via PM!)
I have used a JVC HR-S9600 for a few years. I can say that S-VHS ET on my machine (using high-grade or pro-grade) is close in image quality to actual S-VHS tapes which cost twice the price. However, the audio quality sounds clearer on the higher grades. The 9000 series has image enhancement circuits like DNR (digital noise reduction) and Digital R3 (edge detail enhancement). It also has Active Video Calibration (which tests the tape for a couple seconds before recording to equalize the video signal to the specific tape being used). Has a time base corrector (playback only) to stabilize jittery tapes. The 9600 has the best tuner I've yet seen on any piece of consumer equipment (even better than the one in my DVD recorder) - it even makes cable TV look clear and sharp. It also plays back VHS and S-VHS tapes with the best picture I've yet seen from either of those formats. Sometimes you can see the machine actually "focusing" the picture as it starts to play back, adjusting to get the perfect balance. The machines below the 9000 series aren't quite as good, but of course they cost less too. If you can afford it, I'd try to get one of the 9000 series machines. These things used to cost $1000 some years ago - now you can buy them for $400 new.
While it's never a great idea to let a tape sit idle on the heads, on most standard consumer VHS machines or when using actual S-VHS tapes on decent consumer or Pro-sumer models, there's likely to be no glitch of any sort if you wait out a block of two minutes worth of commercials.
However, on every JVC S-VHS deck I've had (three so far), when recording using ET, even 30 seconds worth of Record/Pause winds up leaving a noticeable glitch and roll of visual static. They make mention of this briefly in the fine print of the manuals, but don't go into specific detail.
I've also found that while S-VHS tapes hold up better through multiple gens than standard VHS, as you go down a few times, you'll start to notice a lot of drift and oversaturation in the colors, as opposed to a more evenly distributed degradation of picture quality.
I hope this helps, and I look forward to participating more on these boards in the future."An intellectual carrot? The mind boggles!" -
Just looked up the JVC homepage and the only available 9000 series is HR-S9911U. Does anybody have that machine? What's your thought and would like to hear your feedback before I can buy it. The retail price is $600.00.
Thanks!
VCR buying guide (S-VHS / D-VHS / Professional)
By lordsmurf in forum RestorationReplies: 326Last Post: 2nd Sep 2025, 05:10 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 00:54 -
I would like to buy a VCR S-VHS Panasonic...can someone suggest me which of
By Giasan in forum RestorationReplies: 2Last Post: 12th Nov 2011, 16:50 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 08:19
