I'm looking for a program to make DVD case labels.
Any suggestions?
Even a template for Word would suffice.
Thanks.
Results 1 to 11 of 11
I'd rather die of thirst, than drink from the cup of mediocrity.
i just scan the label using paint shop pro and print to a thicker paper and use a cutter,thats if you are talking about the movie type of cases.
Just $100.00 and you are in business. Cha-ching! Cha-ching!i just scan the label using paint shop pro and print to a thicker paper and use a cutter,thats if you are talking about the movie type of cases.
Hello. -
I use paint shop pro myself,windows own paint will workOriginally Posted by Tommyknocker
Yep nero 5 does.Originally Posted by K(c)offee
Just import your finished pic into cover designer and off you go. Templates are there for you.
You could always try microsofts site as i'm sure someone had done a template of office that will work in word.Not bothered by small problems...
Spend a night alone with a mosquito
CD/DVD has ripped label, how do I fix it?
By videohalp in forum Newbie / General discussionsReplies: 6Last Post: 12th Apr 2009, 06:20 -
External case - 3.5 or 5.25 case....
By kenmo in forum ComputerReplies: 3Last Post: 2nd Jan 2009, 15:54 -
need psd template for cd/dvd label
By wingfan in forum MediaReplies: 3Last Post: 22nd Dec 2008, 13:25 -
DVD Label Printing Advice Needed
By jday in forum Authoring (VCD/SVCD)Replies: 3Last Post: 14th May 2008, 19:35 -
Printed DVD label color washin out
By anubis13 in forum MediaReplies: 19Last Post: 15th Oct 2007, 10:55
