Results 1 to 10 of 10
    Jan 2003
    Milwaukee
    On my webpage;
    After I typed what I want; how do I create it to scroll down using java or html code? Or is there anyother way if java and html can't do it?
  2. Here is how to create an up/down arrow that scrolls as you move your mouse over them. You could probably easily modify it to become automatic iff need be.
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
    Jan 2003
    Milwaukee
    What do you mean modify?
  4. Originally Posted by Johnnylee_hang
    On my webpage;
    Do you mean like a simple scrool thing like on the right of yoru screen?
    Jan 2003
    Milwaukee
    my mistake........I don't mean that bar scroll down.........
    I want the auto scroll down texts. For example, like getting credits to whom ever making the movie.
    I'm not also talking about putting into movies.........I want to know how to do it in the website.
  6. Member Ziffelpig's Avatar
    May 2003
    Soviet Canuckistan
    Just shut up and listen dumbass
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    or do it all in flash with swish --- which is simple to use
    Jan 2003
    Milwaukee
    <MARQUEE behavior=slide direction=up height=60 scrollAmount=1><center><TABLE width=600><TBODY bgColor=black><TD><MARQUEE direction=down height=60 width=600><MARQUEE direction=left scrollAmount=12><FONT color=orange>  /
    ★</FONT></MARQUEE><MARQUEE direction=left scrollAmount=10><FONT color=yellow>  /
    ★</FONT></MARQUEE><MARQUEE direction=left scrollAmount=8><FONT color=skyblue>  /
    ★</FONT></MARQUEE></MARQUEE></TD></TBODY></TABLE></MARQUEE></center><MARQUEE behavior=slide direction=down height=60 scrollAmount=1><center><TABLE width=600><TBODY bgColor=black><TD><MARQUEE behavior=alternate direction=up scrollAmount=1 height=58 width=600><MARQUEE behavior=alternate scrollAmount=1><FONT color=orange>ここでは</FONT><FONT color=skyblue>タグの組合わせによる素材</FONT><FONT color=orange>を提供します。</FONT></MARQUEE></MARQUEE></TD></TBODY></TABLE></MARQUEE></center>
  9. Member Conquest10's Avatar
    Chicago, IL
    no html on here.
    His name was MackemX
    Jan 2003
    Milwaukee
    [marquee]Scrolling Text[/marquee]
    Something like this, but scroll up instead.
