Is this possible to do because I have some killer floor speakers but they are 4 ohms not 8 ohms like my satellite speakers and I don't want to fry a new receiver.
You might want to take a look and ask a question here (in the "discuss" link at the top of the page)
http://www.ecoustics.com/
Since your 4 ohm speakers will be a large load to a 8 ohm amplifier, it's probably not recommended to do this, keep in mind the impedance of the speaker is nominal , meaning it will change impedance and therefore the load on the amp depending on the frequency of the signal. The amplifier will see it as a lower resistance at the lower frequencies. Of course, you could hook up 4 ohm resistors in series with the speakers, but then you're just wasting the output power as heat and getting nothing in return, also a bad idea.
Sometimes you might not have a problem with using the lower impedance speakers with the 8 ohm amplifier, but a lot depends on the power supply. If it has enough current to handle the higher load, it might work. As long as it has overload protection, such as a relay that cuts out to protect the outputs, you wouldn't have to worry, just hook it up and try it. However, as I said, a lot depends on the design of the amplifier itself. Try looking for more information about your specific model on that website, if there is information about your unit.Ethernet (n): something used to catch the etherbunny
PC Speakers, which ones?
By SE14man in forum Newbie / General discussionsReplies: 8Last Post: 28th Sep 2011, 14:41 -
Newbie question, connecting speakers to A/V receiver
By mordeckai in forum Newbie / General discussionsReplies: 2Last Post: 13th Aug 2010, 17:31 -
DIY speakers?
By Haopengyou in forum Off topicReplies: 3Last Post: 20th Jun 2010, 23:33 -
Does 7.1 audio limit the rear speakers and divert to the side speakers?
By yoda313 in forum AudioReplies: 0Last Post: 4th Oct 2009, 09:55 -
5.1 Speakers over two computers
By SIRCOOKS in forum ComputerReplies: 1Last Post: 31st May 2007, 10:43
