can anyone please tell me the difference between divx and xvid.
Thankyou
Results 1 to 10 of 10
They are both video compression codecs that are used in .avi video files. Divx definition and Xvid definition.
As for the differences, well.......maybe one of the experts can supply more info."Art is making something out of nothing and selling it." - Frank Zappa -
I have the latest Divx Pro version and Xvid...
to be honest I like the results of encoding with Xvid more than with Divx -
I like Xvid myself. Though I dont think I have ever made any divx movies. The quality of the Xvids I have made is great infact I was suprised at first. The main reason I picked Xvid was because it takes alot less time to encode a movie. DivX takes a damn long time. To much time for me this being my only computer and needing to use it sometimes.
yep, speed is a definite factor as well...
seems Xvid is faster and produces better results...
that's the case for me anyway -
I too prefer xvid, BUT I have never encoded a movie in it as I havent found a suitable application. Something along the lines of dr. divx for divx would be nice. I have tried out encoding a few tests in divx and they were pretty good, but I would say IMHO xvid gives sharper/better results.
ok thanks all for your help and views.
but do i encode divx the same as i would xvid.
i use tmpeg and virtual dub.
Thanks again
Wingman. -
I used Fair Use for most of my Xvids. And right now im finishing up a Xvid I used Gordians Knot to make. Im really wandering how well it will turn out. Its a pretty long movie. 1hour 44 minutes and I made it 700 mbs. I hope for the best.
Ah it looks great. Im thrilled. My most complex backup yet and it turned out great. 2 days on and off getting the setting right.
Only made one mistake mispelled "Soldier" in the filename. I think I can live with having to rename it.
I dunno. I have seen some awesome encodes done in XVID, and likewise I have seen some awesome DivX encodes. However, I have found that Xvd is slower (except for the newest DivX 5.1, to hell with that) that DivX (4.XX 0r 5.0X) and gives more problems - i.e green screen@ begininng of movie, vertical bands across video (kinda like scanlines), difficulty and audio/video sync when encoding back to MPEG-1 or 2. I huess I'm wonderign which build of XVID you all use, as there are several out there.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Would synch mostly occur on DVD to DivX, or XviD to DivX?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 01:01 -
Does divx author reencode Divx and xvid files?
By Onceler2 in forum DVD RippingReplies: 4Last Post: 26th Aug 2008, 18:16 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
