hi, i use my standalone philips dvdr70 to record stuff, which records my discs region 0, if i then rip my dvds using dvd decryptor and burn the ripped files in my nec 1100a dvd burner, are the end result dvds region2 or region 0?
i used dvdinfo to find out my dvd burner is region 2, but dvdinfo wont tell me what region my burnt discs are. if my discs will be region 2 using my burner, can i make my burner region 0 without too much risk in breaking it and rendering the drive unuseable if flashing the firmware goes wrong?
you don't need to rip anything. do a direct copy from your rom to burner...save at least half the time. the disc from your standalone is not encrypted. if you have no rom, drag and drop the contents to your hdd and then burn. good luck. BTW you know that region0 is NO region (therefore playable everywhere), right
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 17:12 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 10:26 -
Region coding on burned disks.
By sambat in forum Authoring (DVD)Replies: 6Last Post: 14th May 2010, 17:59 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 13:58 -
How to Make a Pioneer DVR-520H Region 1 a Region Free player?
By Ossocao in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th May 2007, 22:35
