i need to extract an audio track of a dvd i have and want to know what is the mosr user friendly software is, i have downloaded besweet and a GUI
but i get confused how to do it
anyone point me in the right direction??
Results 1 to 15 of 15
look for shareware stuff that does DVD to MP3 or wav ripping (one-click procedure). IMTOO DVD Audio Ripper is one vendor ($30). DVD to mp3 v3.0 from another i cannot think of. good luck
i know this may sound dumb but what do i use to rip the vob files???
ok ive done that and it has created several file into my chosen folder....V.O.B files and B.U.P files VTS file and a TS file whats the next step, cant seem to understand the guides ???
Click on the link in my sig. it works like a charm.
If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
Want to extract audio from .vob files? Read my guide at https://www.videohelp.com/forum/viewtopic.php?t=187078 -
thanks for the advice guys ive just done it i used
dvd decrypter
dvdtoAVI
AC3tool
quality seems fine, thanks for sticking with a newbie to this sort of stuff!!!! -
AAARGH
got up thi smorning to do some converting and the thing wont work, im sure im doing what i did last night, I go to dvdtoavi and open the vob file, then goto audio and select track, then select decode output to wav , then save project, BUT it wants to save it as a DVDtoAVI project!!!!!! and last night im sure it saved as a WAV file as i used ac3tool to change it to MP3 any ideas,im going mad!!!
Ive sorted it!!! what i didnt realise is that i have to dvd decrypt the DVD again to rip the file,
When I take audio from a DVD......I skip one step in your method. I don't use DVD2AVI. I go directly from DVDDecrypter to AC3Tool.
#1 DVD Audio Ripper is what you need.it can rip dvd audios to mp3,wav,ogg,wma.support to edit start time and end time.
http://www.apollo-tech.com/dvd_audio_ripper.exe
Easy ripping with DVDx 4.0
By Starbuck2010 in forum DVD RippingReplies: 41Last Post: 11th Dec 2013, 01:17 -
which freebie software for ripping the audio from AVI and MPG files ?
By soulbug in forum Video ConversionReplies: 6Last Post: 28th Feb 2011, 13:00 -
After ripping bluray to mkv, is it easy to change the audio?
By AndyD in forum Blu-ray RippingReplies: 5Last Post: 26th Sep 2010, 21:24 -
What is the Best/Easy to use Video Editing software?
By jbitakis in forum EditingReplies: 2Last Post: 16th Feb 2009, 12:13 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 10:22
