    Jul 2003
    Exeter, Devon, UK
    Using virtualdub 1.5.7 whenever i encode anything theres is a massive stretch in the audio (about 3 times the length of the origional audio) even if i rip the audio first to a wav. Anyone know whats going on?
  2. Make sure the samplerate is set the same as the file.
    Jul 2003
    Exeter, Devon, UK
    Yeah, i leave the samplerate at no change but its still stretched. if i put it at the same rate as the compression im using its fine. But i used to use 41000 or whatever it is for every compression with no problems. Its weird, i have no idea whats going on!
