I have some laserdiscs that have a multichannel AC3 (well, Dolby Surround is the official name) audio track on them. I am assuming that there is more than 2 channels present, which is all my sound card can handle.
What audio cards do you guys use to capture these multiple channels?
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Wrong Assumption. Dolby Surround sound has 2 real channels. Does your LD player have 6 RCA connectors for Audio?
It's actually a MUX of 4 channels. You get Left, Right, Center and Rear. It's not tru 4 channel, that is you don't have 4 distincitve full audio tracks going at once. It's better than stereo but not nearly as good as AC5.1 .To Be, Or, Not To Be, That, Is The Gazorgan Plan -
According to the literature, this disc was released with both PCM and AC3 5.1 audio. The player itself has only the two audio out jacks, plus the AC3 RF output jack. The output from this AC3 jack is fed into your A/V receiver with an AC3 demodulator. It is split into its separate channels in the demodulator. If I have these six channels, what do I use to cap them - simultaneously?
first, you need special hardware to even try and record a RF AC-3 signal directly. the best bet is to use line-level signals of the decoded 5.1 mix, such as pre-amp outputs from your receiver, or use a line-level tap from your speaker outputs (NOTE: DO NOT CONNECT SPEAKER LEVEL OUTPUTS DIRECTLY TO A SOUND CARD INPUT)
i think it'd be possible to record 3 simultaneous stereo WAV files, provided you had one or more sound cards totaling 3 stereo input channels. (usually this would be 3 cards). open 3 cool edits and set them all to record. you would need to delete some silence off the beginning to sync them up, but there's a trick for that - start playing the movie, then after sound starts, go back one track - so there's a sharp cut in the wav files. that'll help line them up.
Vegas 10: saving audio tracks to seperate .wav file
By Toastie in forum EditingReplies: 8Last Post: 6th Mar 2011, 22:50 -
Record (capture?) directly to the pc...not to tape first
By bobogs in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 3rd Jun 2009, 06:55 -
Trying to dubb/capture both audio tracks from DVC to PC
By Jerry1964 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 28th May 2008, 22:55 -
Capture/Record XBOX360 HELP!
By dpunkz in forum Newbie / General discussionsReplies: 7Last Post: 14th Apr 2008, 10:38 -
VGA Capture and record?
By shifterkart in forum Newbie / General discussionsReplies: 2Last Post: 9th Feb 2008, 11:52
