I am confused what the difference is between just burning a mpeg file by itself vs. burning a cue/bin to make
a standard svcd. Does the svcd structure just allow for subtitles, additional audio, etc.? The reason I ask is I have been using dvd2svcd to make svcd and I burn cue/bin and everything works fine. But sometimes when I download small mpegs I have burned the mpegs directly so in my dvd player I can choose which file to play. Downloaded mpegs work fine doing this, but when I get small avi files and convert them to mpeg with dvd2svcd and burn them directly it plays back blocky/skips. When I make a cue/bin out of the same small mpeg using VCDEasy, then it plays ok. I know how to use VCDEasy to put multiple small bins on one disc, but then it plays right away in dvd player instead of being able to select the mpegs. Thanks
theres a whole file system on a SVCD:
Go to the section labeled SVCD File/Folder Structure at https://www.videohelp.com/svcd there's a lot more to it then putting an mpeg on a cd.Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
also, SVCD has tons of features not useable by raw MPEG iso lite selectebale audio/subs, chapters etc....
And an 80 min. CD will hold 800 Mb as a VCD vs. 700 MB as a data disk.
How to properly multiplex raw mpeg-4 asp into an .avi container?
By Selur in forum Newbie / General discussionsReplies: 5Last Post: 8th Apr 2012, 10:09 -
muxing raw h264 with raw g711 to mp4 continer
By niror in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2011, 11:25 -
How to strip ip header from raw mpeg
By aj99v in forum Capturing and VCRReplies: 0Last Post: 11th Mar 2010, 13:54 -
Mux raw subtitle streams in a existing mpeg file.
By etvideob in forum LinuxReplies: 0Last Post: 14th Aug 2009, 02:22 -
burning 1 hour of raw footage onto DVD
By sfischer in forum Authoring (DVD)Replies: 2Last Post: 8th Feb 2008, 20:28
