Just hooked up the sat dish yesterday and all worked fine. The first time I accessed the TV function off the control panel my system crashed. I restarted and tried again and the tuner worked like a charm. I recorded a few shows went to bed happy thinking I had this dialed in. Today its a no go. Everytime I try to open the TV from the control panel my system crashes/reboots. I've looked thru the archives here and there are a few discussions about ATI instablity but most were about older versions of thier software. I'm running Catalyst 3.1 & 8.1MMC. I've downloaded the latest version from the ATI website: Catalyst 3.8 & MMC 8.7 but was unable to update completly so I went back to the previous version. I used the cat-uninstaller utility to rid my system of all the old files but still no luck. I realize I have a conflict somewhere but where?? Any help would be appreciated.
I had the same problem before. I tried everything to fix it. I ended up having to reformat.
Thanks Innershield. I've done that once and as this system is less than a month old the task was not too painful but I'd like to avoid it again if possible. I checked out your system and it appears we have similar setups. Do you have both of your Maxtors set up in Raid0? I spent hours working with the company techs getting this thing tweaked and feel the mobo and raid setup may be the cause. If so I may just can the raid and go with primary and slave for my 2 HD's.
Using Ulead VideoStudio 11.5 plus - system crashes during rendoring
By hvs08 in forum Authoring (DVD)Replies: 6Last Post: 3rd Mar 2010, 00:28 -
MPC crashes Ati video driver - VLC doesnt?
By snadge in forum Software PlayingReplies: 1Last Post: 29th Jul 2009, 13:42 -
System reboots during avi to vob conversion
By MoundTown in forum Video ConversionReplies: 4Last Post: 25th Jan 2009, 06:05 -
System shuts down and reboots every 13 days?
By tinoman1 in forum ComputerReplies: 7Last Post: 28th Apr 2008, 01:04 -
ATI Aiw card in Linux?
By Nelson37 in forum LinuxReplies: 9Last Post: 10th Apr 2008, 14:25
