Hi, for some reason, avi_io would cause an error (that screen where it says it has caused an error and the only button I can click on is "cancel") in the middle of a capture then it goes into a blue screen that says:
Process_has_locked_pages
I thought there was no limitation with avi_io, the error happened today when the file reached 3.96GB. I'm capturing to a NTFS drive using Win2K Pro SP4 and a matrox g400-tv card, using VT3.03, picvideo as compression method, YUY2 at 352x240 resolution. On avi_io, I set 4096 as max filesize and on the "modify disc" section on bottom of capture settings, I entered 10000, and I also checked "overlay". Do I have to add more paths and filenames on the bottom of capture settings? I only added one path and filename. Anyone know what's up or had that problem before? I'm stumped, this happened twice. The first time, it crashed like 10 minutes into it, the filesize was no where near 4GB. Thanks in advance
Results 1 to 1 of 1
FFDSHOW won't install on Win2k
By DanielF in forum Software PlayingReplies: 7Last Post: 27th Apr 2013, 05:12 -
Does WinXP fix a known Win2k problem?
By bevills1 in forum ComputerReplies: 6Last Post: 28th Feb 2009, 23:34 -
Win2K hangs during booting... :-(
By spiffy in forum ComputerReplies: 3Last Post: 9th Apr 2008, 13:23 -
windows explorer in win2K
By fjmr in forum ComputerReplies: 10Last Post: 4th Oct 2007, 17:37 -
What does win2K need for WinMediaPlayer9 to work ?
By DBenz in forum Software PlayingReplies: 2Last Post: 1st Sep 2007, 11:21
