  1. I havent had much experience with burning DVDs. I have around 22 mpegs around 15 minutes each. What I want to do is have a menu that will play them all and then submenus that will play them separately. I would also like to have motion for the buttons (small clips from the mpeg as the button), and background music if possible. What is the best program to do this and please tell me what tutorial is best.
    Thank you.
    Mar 2003
    california
    I would say first convert your mpeg's to DVD compliant mpeg2 files using CUCUSOFT's AVI-TO-DVD (also does MPEG to DVD)
    Then use TMPenc DVDAuthor to make your DVD with menus nd burn too.
    Both program links can be found in the tools section.
