  1. Member Roderz's Avatar
    Jul 2003
    the armpit ofthe Midlands
    Hi
    Been using MainConcept MPEG Encoder to capture to mpeg2 dvd from vhs
    Capture - all goes well and audio is in sync.
    However
    play back in WMP - fine audio+video
    play back in PowerDVD - video - NO audio
    Import file to TMPGEnc DVD Author - fine audio+video (48KHz 224kbs)
    playback vobs in powerDVD NO audio!
    view mpeg file in AVIcodec - Audio : 0.0 B, 0 Kbps, 44100 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported !!!!!
    Any idea's
    Also converted a TextureLoop.AVI from MainConcept website to dvd mpeg2 (default settings) to use as motion backround, avi is 4seconds long pal 100 frames but resluting mpeg file is 3 frames short - plays to 3:21 !!
    What am I missing here?
  2. Member Roderz's Avatar
    Jul 2003
    Update
    The 1st prob is still there (but plays fine on settop box when burnt onto dvd)
    The second prob with the 4 second loop is still there no matter what I do,
    encodes full 100 frames if I use TMPGEnc (plays to 3:24)
    Ant ideas
