Was able to do two LVCD's succesfully from dvd'z. The quality rivaled divx, at 352x240, ntsc. played on my apex, no problem, even full screen on media player looked great. Smooth, audio was always in synch. no off synch on watching on tv. if i fast forward, on da pc,then play (slight off synch, fastforward again, it gets back in synch). ditto for the apex-1500. Both of these were smartripped to the hard drive before encode.
however, now after successfully, ripping two movies, and burning with nero,,, (updated to 5.5.0.4) and trying dvdx 1.4 to 1.5a, DvDx wont encode, from hard drive or dvdrom, it will start to encode and then stops after either 2 minutes, or 3 hours.usually 2 minutes...
i've tried all settings, that are available to tweak, detect 24 fps on and off, different bitrates, different framerates, etc, all. mpg1 and 2, standard compliant and x(s)vcds...and still wont encode, tried all the aforementioned versions on two different dvd's and two computers, to make sure it wasnt pc/codex related, under win98se and win2kPro (Freshly installed)...
Anyway, if anyone can assist, its much appreciated.
Great lil program though.
Zooter
Results 1 to 1 of 1
How Can I Correct This Collor-Problem? (Sample Inside)
By MrJacobAngle in forum RestorationReplies: 105Last Post: 9th Aug 2010, 12:17 -
Sample error on separate source means video & audio out of sync!
By christowe in forum MacReplies: 3Last Post: 13th Jan 2009, 14:22 -
DVD --> x264 MKV - I think I'm having an interlacing problem? (Sample Vo
By mob in forum DVD RippingReplies: 13Last Post: 14th Apr 2008, 21:43 -
Error in DVDx?
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 15:17 -
inconsistent audio sample rate error in FCE...
By ednarophati in forum MacReplies: 1Last Post: 23rd Aug 2007, 14:59
