Recently when putting a DVD+RW in my Sony DRU500A DVD burner, an error message appears. The error appears when using the Drag To Disc feature of the Roxio software. The error is titled Windows Explorer and reads Drive E Is Unaccessable. After I clear the message, the drive uses Drag To Disc without problem. Normally when I put a DVD+RW disc in the drive, a window opens displaying the files on the disc. This no longer happens and the error message appears. Could any one help me with this problem.
Thank You
What are you doing?
I don't have ROXIO's newest (6) but follow me here..
NEVER USE DRAG TO DISC
it creates a un-finalized DVD DISC that will not read in other dvd-rom drives
go to add remove.. please remove ROXIO 6..
and re-install without the "DIRECT CD" component
this component will confict with burning DVD's in many cases..
SO, you've been warned..DO NOT USE DRAG TO DISC
please burn the files(I think they call it 'CLASSIC' in ROXIO 6) to your DVD-RW and format and erase in between uses
Anyone have a different opinion?
Did anyone know If DIRECT CD(drag to disc) works in 6?...It was useless in 5--- unless you are a corporate worker in a fortune 500 company that only uses DVD burner to back up doc's (NO VIDEO USES) -
I agree with you about version 5, but version 6 does finalize the DVD+RW disc everytime it is ejected. These discs once they are ejected, can be read on any DVD-ROM drive. I do this all the time. To date, which has been since version 6 has come out, I have had no conflicts, caused by Drag To Disc, with my other burning software. Anyway, thank you for your reply!
Burning DVD's with Roxio Creator Basic 9 or Windows DVD maker
By bhess55 in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2008, 02:55 -
Newbie Roxio easy cd and dvd burning question.
By mmmipa in forum Newbie / General discussionsReplies: 8Last Post: 24th Nov 2007, 21:31 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 15:27 -
Roxio Easy Media Creator 10 verses Pinnacle Studio 11
By snuggels in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 12:10 -
Roxio Launches Easy Media Creator 10
By roxann in forum Latest Video NewsReplies: 0Last Post: 5th Sep 2007, 15:27
