I am currently running a 2GHz machine with Windows XP.
My video capture device is a Pinnacle PCTV RAVE pci card.
I am having problems in increasing the resolution above 352 x 288.
When the software which came with the device is run there is an
option to select the resolution. A drop-down allows for selection of
MPEG1 or Miro XL (???). A further drop down allows for a change in resolution.
For MPEG1 this is fixed at 352x288 but for Miro XL you can increase it
above this but only in 3 steps.
This window also has a selection list VCD, SVCD, DVD - but this is
greyed out.
The only problem is that this resolution increase is not stored. When
VirtualDub is run it refuses to accept a resolution increase. A ULead
trial application will throw a cryptic error if the resolution is
set above 352 x 288. In the resolution window 352 x 288 is tagged -
default.
Any suggestions to increase this resolution and keep it there ?
Results 1 to 1 of 1
Software for Pinnacle PCTV usb2
By jodal in forum Media Center PC / MediaCentersReplies: 11Last Post: 28th Apr 2010, 06:32 -
pinnacle pctv 310i
By marc21782000 in forum Capturing and VCRReplies: 10Last Post: 4th Jan 2010, 03:30 -
What software for Pinnacle PCTV HD?
By tomreedtoon in forum Capturing and VCRReplies: 10Last Post: 9th May 2009, 07:14 -
Pinnacle Studio PCTV upgrade?
By visionman in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2009, 14:41 -
PCTV Rave Card - trouble capturing xbox + tv audio
By chocolate_brownie in forum Capturing and VCRReplies: 2Last Post: 24th Jul 2007, 09:38
