Just being viewing posts and see that there is a direct x 8 patch mentiond for capture improvements.
Anyone know:
what the improvements are
any other issues such as compatibility probs.
member : RaleighNC, it was in your post so any more info you can supply would be gratefullly received.
By the way has anyone being running virtual dub 1.47 in comprison to 1.45. Is it just my imagination ordoes version 1.47 seem a bit more unstable and prone to random frame drop.
scattergun
the patch is a digital video update, and I did not notice any difference after installing it except in virtualDub when you press capture and it brings up the confirm button, the audio cuts out.
http://www.microsoft.com/directx/homeuser/downloads/
for the patch. it is built in to winXP but installable from all other OS.
as for more dropped frames, havent noticed any from 1.45 to 1.47. though 'random' frame drops aren't really random, they are dropped to keep audio timing between video frames and audio frames. -
Anyone can help... me problem is audio dropping in VirtualDub... my pc is fast enough to capture full D1 video frames but it somehow complain in VirtualDub that audio is being drop and ask for me to reduce the audio capture rate??.... WHY??...
you are probably trying to capture audio in a compressed format, like mp3 or divx audio.
try capturing audio in PCM CD Quality and let us know.
VHS to pc patch cable
By Dr.Gee in forum Newbie / General discussionsReplies: 11Last Post: 7th Apr 2011, 07:43 -
Create DVD Audio Patch?
By Spawn1985 in forum Authoring (DVD)Replies: 23Last Post: 3rd May 2010, 23:25 -
Removing PowerDVD 8 Patch Notice
By J8son in forum Software PlayingReplies: 2Last Post: 4th Jan 2009, 20:52 -
Background/ Splash screen patch in the UK
By stavdav in forum DVD & Blu-ray PlayersReplies: 3Last Post: 30th Nov 2007, 10:13 -
ProjectX - possible to patch?
By netmask56 in forum DVB / IPTVReplies: 1Last Post: 21st May 2007, 00:18
