352 x 288 or 352 x 480 0r 352 x 576 ..???
any suggestion
thank's
celulux
720x576................
should I deinterlaced during capture for this resolutiion?
my final source is pal vcd -
If your source is VHS or SVHS, then 352 x 576 is what you need. With PAL, capture higher doesn't help like with NTSC.
If your source is an amazing clean aerial transmission, try higher (704 x 576 or 720 x 576, depending what your card supports). The use of S-Video cables is needed for those framesizes! -
As you want VCD at the end of it there is no point in capturing at a higher resolution and then changing the size when you encode. PAL VCD is 352 x 288 so capture at that size to start with.
Recommended is 352x576 capture resolution with 2:1 resize in Virtualdub
I find it best to capture at full DVD size and reencode to VCD- have done full movies from TV that way-results are better than commercial VCDs- when i have used 352x288 size for capture the results have been crap- have been ashamed to admit they are my captures to family!!
PAL - what is its resolution in 16:9 broadcasts?
By snadge in forum DVB / IPTVReplies: 19Last Post: 22nd Oct 2013, 07:01 -
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 02:10 -
Changing AVI Properties (Resolution, FPS etc) NTSC>PAL
By skywalka in forum Video ConversionReplies: 4Last Post: 7th Mar 2011, 21:45 -
how to convert ntsc to pal without changin the resolution?
By Remyisme in forum Newbie / General discussionsReplies: 6Last Post: 27th Mar 2009, 18:30 -
PAL is bigger resolution than NTSC....?
By snadge in forum Newbie / General discussionsReplies: 17Last Post: 19th Jan 2008, 13:18
