Is there a way to distribute the encoding of an MPEG across multiple PCs using either frameserving or some other method? I want to use TMPGEnc if at all posible. If not I want to use trialware or freeware tools.
I cannot get the gist of your question. Will all the computers share the same file, or will they share the same encoding task. Please clarify.
Hello. -
(correct me if I'm wrong) he's talking about using multiple linked machines as a processor boost, like what 3D apps do in "render farms" - coordinate a network of computers to do the encoding on a single media file.
the problem would be finding a program with support for running across a network or cluster of that nature. I know that Cinelerra will do it under Linux, but I'm not sure if that includes an mpeg-2 encoder.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Housepig is correct, that is what I want.
I only have linux on one computer. The others are reserved (i.e. not mine to install OSes on) so they run Windows. But I have the go ahead to use all the processors for a single encoding task if I want.
Revolution in computing - The New HP Touchsmart
By cplevel42 in forum Newbie / General discussionsReplies: 15Last Post: 10th Sep 2011, 02:50 -
Distributed video encoding
By exiled350 in forum Video ConversionReplies: 8Last Post: 10th Nov 2010, 00:28 -
Eye Opener: Cloud Computing Power Requirements
By ahhaa in forum ComputerReplies: 3Last Post: 31st Mar 2010, 07:16 -
DivX network distributed video encoding
By logicom in forum Video ConversionReplies: 1Last Post: 24th Nov 2008, 10:42 -
vegas distributed processing question
By aedipuss in forum EditingReplies: 3Last Post: 19th Jun 2008, 22:30
