  1. Is 4x a good speed for Ritek G04's, and a Pioneer 106D?
    I'm going to be buying some G03's or G04's soon and I just want to know if burning at 4x is not to fast, and may lower compatibility
    Aug 2003
    Nova Scotia, Canada
    I have used that combo (A06) and G04s for over 75 movie backups, all at 4x, and had only one disc that had issues. Even that disc was watchable, is simply just had some intermittent video skipping. At 4x this combination is incredible reliable.
    "640K ought to be enough for anybody."
    - Bill Gates, in 1981
  3. Good choice Ma8t, I have a 106/A06 thats all I use is Ritek's G04. I have used em for the past 3 months, great disc's! But NOW you can get them @ NEWEGG.COM they are cheap tooo!! Only $57.99 for the 4x G04 with FREE FedEX Shiping!!
    Dec 2002
    NEC 1300A at 4x rocks. Less than 15 minutes for total burning. Using RITEK G04's @ 5 for $5.99 on sale locally. My first 50 had only 3 coasters, all from DVDDecryptor not supporting buffer underrun correctly.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  5. Gazorgan
    were you using 3.160 or 3.170? does the latter support buffer-underrun correctly thanks
