I currently am on dial up but not for much longer. I use sygate personal firewall the free version but wanted to know more about zone alarm and how it compares. Can both run at the same time or would you recommend one over the other??
Let me know.
Thanks :P
Never used either, but I would NOT suggest running both. I get calls from customers all the time that have 2 virus scannrs and 2 firewalls and say "I thought I'd be more protected" Pick one of each and keep them up to date. THen you'll be more protected, AND have more resources.
If I were you I'd just get a broadband router with a hardware firewall, never had an issue with the built in ones. -
zone alarm works fine on winxp/pro on broadband. never used sygate, so cant comment. Did previously use outpost, But I stopped for some reason, cant remember why.
DONT use both, i tried that and they interferred (or however u spell it) badly. They just kept havin arguments
with each other and giving me loads of problems, DONT!
My machine crashed numerous times after I retardedly install McAfee and Norton firewalls.
Thanks for the replies...the information helps. I will just continue to use what I have been using that works best.
Thanks!
HD Video encoding, CPU alarm going off
By swillw in forum Newbie / General discussionsReplies: 8Last Post: 13th Feb 2011, 10:16 -
Zone Alarm Headsup
By ranchhand in forum ComputerReplies: 10Last Post: 9th Jan 2010, 04:07 -
Free Safety Patch from Zone Alarm - Today Only
By MJA in forum ComputerReplies: 0Last Post: 12th Aug 2008, 15:50 -
Free Zone Alarm Forcefield.
By wtsinnc in forum ComputerReplies: 2Last Post: 11th Aug 2008, 03:14 -
Looking for a region free /zone free DVD Recorder. Questions about the zone
By perdue27 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 10th Mar 2008, 14:09
