How do I connect a VCR, DVD and a Cable Decoder to my Television.
They all have two scart connectors apart from the DVD which only has one. I would like to record from the TV, DVD and Cable if possible.
I would also like to connect my PC to the TV sometimes, or is this too difficult.
Hoping you can help ................... David
By a switching multi scart box. Not sure of a retailer out where you are but do a search I am sure you will be able to get one imported.
Thanks hardcoreruss, I was hoping that somebody would come up with a solution that would not cost me much money as, like you say "if it's wet drink it" and that what we expats like to do in Las Palmas. Thanks anyway, will check the net for mail order firms.
If you are ever this way I will get the beer in :P
Panasonic DVD & USB & SD Card Slot Problem
By Tim Sage in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2011, 19:23 -
Noob Troubles: DVD w/ Multi-Angles & Commentary + m2v & ac3 joining
By ssfblue in forum Newbie / General discussionsReplies: 5Last Post: 28th Nov 2007, 12:54
