I recently bought an LCD monitor which I'm using with the digital connection. In digital mode the only monitor setting that can be changed is brightness. Doesn't that make it impossible to calibrate the monitor?
Results 1 to 9 of 9
you should be able to do from windows -- using colorific at the least . many panels come with a color calibration program .. if not use this http://www.colorific.com/
there are better programs also to do this .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
My monitor came with software but I've never had good results with a software only approach. If I get a hardware calibrator I know I will get a good profile but if I can't adjust rgb then I won't be able to calibrate the monitor.
Originally Posted by Michelle
you should be able to use software and get a good results ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
hi Michelle pal..
Is there anything wrong w/ your LCD that you have to adjust the colors ??
I have the NEC MultiSync LCD 1555v 15" screen and works great for me.
I had to adjust the colors (as best as possible) using the onscreen route
and it took a while for me to match a "best" guess, but I'm happy w/ my
results and I haven't had it change on me since.
I must admit, that it took a little while getting use to it, because it's not the
same as an CRT tube - richer colors etc. but that's the way LCD is, ..not
so rich in color, but still great for video.
And, I use mine at the fullest res of 1024x768. Even when I shoot some
video of the screen w/ my TRV-22, it looks pretty good - no Interlace
Anyways, I was just curious about yours. Hope you didn't mine my input.
-vhelp 2069 -
Originally Posted by vhelp
Originally Posted by BJ_M
we use sencore hardware calibration equipment ... http://www.sencore.com
I called ColorVision whose CRT calibrator worked well for me and is within my budget. They said their software is capable of handling monitors that don't have color control.
Connect LCD monitor to Digital HD Cable box?
By rogerconnery in forum DVB / IPTVReplies: 84Last Post: 18th Jan 2012, 06:04 -
Lcd Tv as monitor
By alldonein in forum ComputerReplies: 2Last Post: 10th Jan 2010, 14:46 -
LCD TV vs. LCD Monitor for PC gaming
By Xenos80 in forum ComputerReplies: 6Last Post: 12th Feb 2009, 23:01 -
Displaying Photos on an LCD Monitor or LCD TV
By jbsiegel in forum DVB / IPTVReplies: 3Last Post: 25th Sep 2007, 12:29 -
Help on a LCD Monitor
By wasabiboys in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 04:58
