I've recently purchased a Pacific 1002w DVD player from Asda on the knowledge that it will play most of my mpeg files that i have on CD. All those that are in the SVCD format work fine, and the player is capable of reading MP3s written to CD. However, unlike my friend's 1002 player, it cannot play straight mpeg files.
I've entered the multi region code and the macro code that i found by searching this forum to see if that would help, but it still doesn't work. Does anyone know what is the problem?
yep.they changed the firmware.
theres nothing you can do,apart form look at the sets of stars on the box.
2 sets of review stars,and it played mostly all,3 sets and its newer,and most likely changed a bit.
they also disabled some things like certain parts of the zoom function,and the ability to play(on some models) dvd+R.
it still makes a weird sound when you play some cds/dvds.
some do and some dont,but they know about it,but must be getting made a lot cheaper if they use that noisy drive.
its an ok player for the money,but a tiny bit cheap looking.
the best drive ive seen lately,is the ALBA DVD55,available from toysrus,in the UK,and its £39.99.
good quality,plays everything ive thrown at it,and its cheap too. -
I've just tried it and it mine does play straight MPEGs - didn't know about that one 8)Originally Posted by slyguygi
Don't know of a macrovision hack that works though.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
Can someone help me please Pacific dvd
By jackplug in forum DVD & Blu-ray PlayersReplies: 18Last Post: 21st Apr 2010, 13:12 -
Durabrand 1002 DVD Player
By markyl in forum DVD & Blu-ray PlayersReplies: 4Last Post: 6th Dec 2007, 12:56 -
Philips 1002 DVD not working: CD's are
By gunnsr in forum Portable VideoReplies: 1Last Post: 20th Oct 2007, 16:50 -
Pacific DVD-1002 hacks
By mark2004uk2 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 26th Jul 2007, 10:22 -
Pacific Digital U-30297 External DVD+RW
By vaporware in forum DVD & Blu-ray WritersReplies: 1Last Post: 11th May 2007, 12:35
