  1. I have a quick question. I usually burn my vcd's without a menu of any sort, but I decided to try out the vcd menu option included with Nero 6. I loaded up all the movies as normal, set up the preview picture, made captions and included a background picture. Burned it at a lower speed, and everything seemed fine. However, when I play it in my DVD player (Its a Panasonic DVD-CP72), it will show the menu screen for about a second or two, then the picture goes black. Did I do something wrong with the options in Nero, or is it most likely just an issue with my DVD player? Thanks for any help.
  2. Normally Nero Express sets the menu to play for an indefinite time, however you could check by switching to Nero- Burning room before burning the CD. To the right of the Menu file you should see how long it is set to display and you can change this setting by double-clicking on the Menu file... It's worht a try
