I have 40hm floor speakers and am building a home theat. syst from scratch. I also have satellite speakers that are 8ohm impedances. I just wonder if a 6ohm receiver vs. an 8ohm receiver will have less strain and heat since it is closer to 4ohm than the 8ohm receivers. Anybody have any input for me?
You can use a 4ohm receiver on 8ohm speakers but not the other way around because you might fry your amplifier.I suggest buying a new crossover or new speakers.
Yes, just the receiver. I am using a really old one right now and it doesn't support dolby digital etc. That is why I want to get the receiver separetely and the speakers separetely.
Can't I do that?
PC Speakers, which ones?
By SE14man in forum Newbie / General discussionsReplies: 8Last Post: 28th Sep 2011, 15:41 -
Newbie question, connecting speakers to A/V receiver
By mordeckai in forum Newbie / General discussionsReplies: 2Last Post: 13th Aug 2010, 18:31 -
DIY speakers?
By Haopengyou in forum Off topicReplies: 3Last Post: 21st Jun 2010, 00:33 -
Does 7.1 audio limit the rear speakers and divert to the side speakers?
By yoda313 in forum AudioReplies: 0Last Post: 4th Oct 2009, 10:55 -
Best computer speakers
By justalice in forum ComputerReplies: 13Last Post: 11th Apr 2008, 14:34
