I have an episode of unlicensed anime that I got off bittorrent (to keep you legal eagles off me it's unlicensed)Eventually, I'm going to convert it to mpg2 for dvd-r consumption.
However, when I play the video, all I get is audio. The video works for about 3 seconds then stops and won't move past that point...exept for the audio.
I've tried GSpot to see if it was some obscure codec, but it came back to a standard Divx format (two drivers for that). Next, I tried VDub to see if it was a bad frame or something that was stopping me. VDub said that there were no bad frames. For kicks, I tried converting it anyway to see if the converted file would sort through the problems, but as guessed, that was a no-go either.
What am I missing here? It's episode 48 of 50, so I can't exactly miss this episode...any ideas?
Can VDub see all the video frames? If so, convert to intermediate file (Uncompress or Lossless/HuffYUV) if you've got the room.
Scott -
I just ran into that same problem....I tried to chop it up in vdub and stitch it back together but nothing beyond the glitch point was recognized. I still havnt found a solution to it.
I had to hunt down a better copy of the file...that seemed to fix the problem.
Thanks guys 8)
How to stream a video stream.
By chackonman in forum Video Streaming DownloadingReplies: 2Last Post: 12th Mar 2012, 14:51 -
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 23:42 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 12:01 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 04:27
