  1. Will the Hollywood-Plus DVD/Mpeg-2 Playback/decoder card play SVCD?
  2. Hi, yes H+ will playback SVCD, VCD, DVD, XVCD.
  3. If you install the latest beta drivers, the DVDstation will also be able to autodetect SVCD.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  4. I'm owner RealMagic Hollywood+ too. It playes SVCD with no problems, but SVCD has to athorized in I-Author !!! When you create SVCD with NERO 5xxx, Hollywood+ recognized CD as SVCD but won't play it . You able to play SVCD burned with NERO in "File MODE" Hollywood+ .
    Good luck Ivo Novak
    Aug 2001
    Finland
    Ivonovak: H+ plays SVCD's created with Nero just fine. At least older H+ drivers just require you to change /MPEG2 folder to /MPEGAV (non-standard) in Nero advanced SVCD options. This option isn't available in the early 5.x versions.
    I think the newer drivers will play SVCD regardless of the folder naming convention used.
  6. H++ plays any type of SVCD, even my own SxVCD which just use MPEG2 it plays great, i'm using latest 2.2 drivers and it just works great.
    Best Regards,
    Sefy Levy,
