Hi, all
How do you create rollover motion button for DVD?
I mean a thumbnail video clip plays and when you rollover it i want the "Arrow" or a "Flower to show next to it.
thanx
I use DVD Workshop.
-Does "dvd-lab" and "tmpgenc-dvd-author" do it?
-Which ones can do rollover buttons?
-Is Rollover buttons a part of DVD Spec? -
DVD-Lab supports this, they call it "switched menus".
http://www.mediachance.com/dvdlab/tutorial/switchmenu.html
Actually now that I think about it, i think you might be looking for a sub picture that shows when the object is highlighted. If this is true, then yes, DVD-Lab can do this too. -
If you just need the pic to use as a faceplate for the button use Photoshop. As for the program behind the pic that adds the funtion, I'm not sure.
I use workshop as well and would like to do this too. I thought that there was a program that did this. I'll research and get back to you as soon as I can.
Can I create my own custom Button in TMPGEnc Authoring Workshop 4?
By JackyWang in forum Authoring (DVD)Replies: 4Last Post: 31st Aug 2016, 22:14 -
How To Create A functional button and replace the DVD menu using free tools
By escarlate in forum User guidesReplies: 4Last Post: 31st May 2011, 01:44 -
Using DVDLabPro to create a "sound effect" button?
By takearushfan in forum Authoring (DVD)Replies: 7Last Post: 1st Jun 2010, 19:53 -
Question about this forum - rollover baloons for certain text?
By Mylo in forum ComputerReplies: 2Last Post: 13th Apr 2009, 11:17 -
Can't get mouse rollover to work when viewing DVD on PC, (DVD Studio Pro 4)
By theMonseignuer in forum MacReplies: 4Last Post: 5th Aug 2008, 09:34
