Having a music DVD which will not play anymore (disk scratched near centre- wont even load on standalone player or PC ) the only software that will open is DVD decrypter, seems to capture all but the last few mins of the DVD.
Problem is the VOB files it created come to 5 gig so wont burn direct to DVD , DVD shrink and DVD2ONE will not open the files so i can compress them says something about not complete. TMPGEnc also wont open them.
Any help will be most appreciated.
John
Results 1 to 17 of 17
Try stream processing. Watch for corrupt files (read errors). Remove those files and re-author the DVD(you should have Audio and Video files when you start). You should come out with the same DVD minus the corrupted files.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thanks......tried that but it just gets to 97% and keeps coming up with "uncorrectable error" option of ignore just brings up another "uncorrectable error" only other option was cancel.. been doing this now for 1 hour and still on 97%.
John -
You are pretty much dead in the water then. That scratch has f---ed you.
Sorry to hear that. I had this happen to a CD of mine. Rare and OUT OF PRINT. A real bummer! -
Well I managed to get all VOBs 1 - 6 and 75% of VOB 7 from DVD Decrypter, used TMPGEnc author on VOBS 1-7 all went well.
Started up DVD shrink and get error message " cannot decrypt VOBS - error unknown" used TMPGEnc author again but same thing.
Any ideas how to get around this?
John
Update ........
used DVD2ONE to get a working backup (well 95%ish) but dont have any option to change to DTS audio or have full chapters.
Could these be part of the DVD that could not be backed up? -
Try Smartripper,it can sometimes rip disks that DVD Decrypter cannot. If you have a DVD-R recoder try ripping with that,it's slower rip speed,2x,can also help in ripping difficult disks.
Id suggest using Smartripper and choose ripping by chapter n choose all the chapters except the last 1 or 2...with a bit of luck youll have your dvd minus the last 5 or 10 mins or so.
Or you can just use DVD shrink 2.3 to do the compression. I just like to use the Deep Analysis in Beta 5 so I do it that way. -
Smartripper couldn't get any more info than DVD Decrypt.
DVD Shrink 2.3 came up with a "file doesn't exist" error
Got all but 1 song on the dvd which is ok, but cannot access the DTS option....I'm just getting 2 channel...and no original chapters -
Longest I've spent on scratched media was 11 hours. Tell DVDDecryptor to re-try reads at 3 and ignore errors. I had 424 errors, and it looked bad when viewing, but I did get enought to backup.
FOO POSTED the answer for you but all ignored it
stop potchkying(?) around with the disc and get to work -
Did you really point DVDshrink at a folder created by Tmpgenc DVD author that contained all the correct files but DVDshrink said there were files missing? -
forgive the previous post
I have had some limited success submitting the .IFO 's to IFO EDIT
in the case of a DVD shrink input error.. Just resaving them can sometimes fix this as its a subtle problem whose nature excapes me -
Have you looked at repairing the disk? There are some kits that can fix minor scratches and some stores have a service that can do it as well for about $2-3 per disk.
Hello. -
Thanks for replys...
I did say I had most of DVD now backed up, just 1 song missing and it aint that special.
The problem was no DTS audio option and no original chapters but with IFO EDIT downloaded I can see the DTS is in there, just gonna be some headscratching to get it as an option methinks!
No chance of repairing original DVD....it's bad...I got kids
Update....
Deleted all but VOBS files then created new set of Ifo files with Ifoedit...worked a treat...have now got a complete (less 1 song) back up of original DVD including DTS and original chapters.....Cheers
John
Freeware for compressing DVD files
By Ricky_E in forum DVD RippingReplies: 59Last Post: 3rd Aug 2010, 13:11 -
Compressing .vob or .ifo files using DVD Shrink
By hostofsorrow in forum Authoring (DVD)Replies: 4Last Post: 21st Jan 2010, 22:19 -
compressing avi files
By romanstopme in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2009, 20:36 -
Compressing ISO files for DVD?
By mr_goodbomb in forum Authoring (DVD)Replies: 2Last Post: 5th Jul 2008, 08:32 -
Compressing AVI Files to Burn to DVD?
By ryevick in forum Authoring (DVD)Replies: 17Last Post: 27th Nov 2007, 21:59
