I keep getting the message "Unable to render graph" it doesn't do it on all DVD's or VOB id's just random ones.
Changing the resolution to 256 colors made no difference. I use XP Pro and an Invidia G Force card. Sometimes VOBrator will show me every VOB ID other times it hangs and gives me that message.
Maybe a newer version is on the way to FIX this problem?
Thanks to all who reply!
J T
Only one released version (and it's beta) of VOBrator. There have always been issues with WIN XP OS.
Sometimes, there is nothing to render in a VOB ID. Always check the number of packets (size) in the box at upper right - small numbers usually indicate nothing to render.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 09:59 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
VOB to wav & m2v and back to VOB
By GordRocks in forum Video ConversionReplies: 2Last Post: 13th Jan 2008, 06:44 -
Missing VIDEO_TS.VOB and all VTS_xx_0.VOB
By PietjePuk314 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 18:44
