I have a movie with a bitrate of 651kb/s. If I want to encode so I can put to disc I can either encode as VCD or SVCD.
For VCD the standard is 1150 and for SVCD it is 1600.
Is there any point in encoding to SVCD since the original file is 651kb/s. Can I actually make the movie look any better if I encode at a higher rate than 651?
Basically, How does bitrates work for DivX movies and whether there can be a choice between VCD or SVCD encoding?
Regards
Mandeep
AVI bitrate has nothing to do with VCD or SVCD bitrate.
SVCD maximum is 2550(including Audio), not 1800.
What an AVI bitrate does is let you know what quality level it is capable of. 651 kbps is good for VCD quality. It may be capable of SVCD quality, but I doubt it.
What resolution is the AVI?To Be, Or, Not To Be, That, Is The Gazorgan Plan
Question about Bit Rate and Quality
By T375 in forum Newbie / General discussionsReplies: 4Last Post: 20th Sep 2010, 10:31 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
Lots of question regarding conversions, bit rate, Xbox 360...
By walterdavid in forum Newbie / General discussionsReplies: 2Last Post: 20th Nov 2009, 23:06 -
HDC setting question, 2 pass + manual bit rate
By jsbenson in forum Video ConversionReplies: 2Last Post: 1st Nov 2009, 20:15 -
Simple bit rate question
By Bully9 in forum Newbie / General discussionsReplies: 5Last Post: 8th Jan 2009, 13:01
