  1. on a G4/Panther
    Some time ago I backed up a DVD. Can't remember what program I used but it gave me one file of approx. 7.0gb called 'TITLE01-ANGLE1.VOB'.
    What program do I use on the above to extract the relevant files for a VIDEO_TS folder so I can then use with DVD2oneX?
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    hopefully you have more than just 1 .vob!
    if not you wont be able to do what you want with dvd2onex
    the app requires input of an ENTIRE VIDEO_TS folder with lots of .vob's in it
    if your have just a single .vob it will be a trickier process.
    so tell me, the backup you have is it an entire VIDEO_TS folder thats 7+ gigs or is it just a single .vob thats 7+ gigs?
  3. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    But if he converted the vob to an mpeg, he could author it with Sizzle, then compress with DVD2OneX.
    Plus, doesn't ffmpegX do VIDEO_TS authoring from MPEGs??
  4. Member galactica's Avatar
    Jan 2003
    yes that would work, but you will loose the menu's if any were kept.
    thus why i say a more involved process. doable - yes, anything is possible.
    same with ffmpegx it will do it, but is he like me and always wants menus?
    if so i guess we just have to wait until your menu tutorial for dvdsp comes out
  5. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Gimme 1 more day on the menu guide. Then more guide will come after that.
    Jun 2001
    Silver Spring, MD USA
    I think you guys are reading these cries for help way too fast (I've done it also). The poster clearly stated his ripper gave him one file that was approx. 7 gigs. So his only option is to use some software (DVD Studio Pro, Sizzle) to author that giant vob as a proper DVD. It will have no menus. Once the VIDEO_TS folder is created then that gets crunched in DVD2OneX.
  7. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    ...isn't that what we said??
  8. Member galactica's Avatar
    Jan 2003
    yea, i glossed over the word ONE in the 1st post. So kill me!
