Okay, I am trying to use VirtualDub to do my capturing because it seems to have the best quality captures so far. My problem is this: I have several differnt 30min shows on one tape and the first 5 went absoulutely wonderful, but I'm trying to capture #6, but the video keeps stoping and starting like it's on a 2 or 3 second pause and then it picks up where the audio is. Why is this happening? How can I make it stop? All help is appreciated!
Well it sounds like you are running out of computer resources. 600 mhz and 128 meg of ram are a minimum system.
But you might try - Turn off any AV sw. Disable any other background tasks. Make sure that the HD is de-fragged. Use Task manager(processes) to see if there any hidden tasks executing. Make sure that DMA is active for you HD. Add 128 meg of ram.
Drop the resoultion (bitrate) on the captures.
I use a 600 Mhz 256meg laptop to capture with USB 2.0 and have done all the above and I dont drop frames. -
Thanks for the reply! I bet my problem has to do w/ other programs running! Yesterday I had everything shut off except VirutalDub and stuff was fine. I'll try and see what happens now!
video that has pauses in it. is there a way to fix things?
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2011, 07:45 -
MPC-HC : audio does not pause when video pauses for H264 video
By kswartz in forum Newbie / General discussionsReplies: 3Last Post: 28th Jul 2011, 01:56 -
Should a power supply be able to survive a momentary short?
By davexnet in forum ComputerReplies: 4Last Post: 30th Jun 2011, 10:37 -
Momentary darkening on JVC HR-S9911
By moxiecat in forum RestorationReplies: 12Last Post: 8th Feb 2010, 18:08 -
Video backups contain pauses
By dadbackup in forum DVD RippingReplies: 10Last Post: 15th May 2007, 15:13
