Is there any reason to encode 5.1 audio to an MP3 to use in a Xvid? I dont know much about how audio works so would there be more information to make the mp3 sound better or should I just use the stereo sound and forget the 5.1? I only have 2 speakers and a subwoofer but I mostly use headphones so I dont much need to encode to 5.1 ogg(I think ogg lets you do 5.1 channels) anyway thanks.
Use BeSweet and convert the 5.1 down to positional 2 channel Stereo (Dolby surround, 4 channels muxed to 2: Left, Right, Center, Rear). Then encode to 160 or 192 kbps MP3. Works very well for something more than stereo.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thanks for the quick reply. Are there any guilds that would explain how to do what you said? Im new to Besweet and I have not found a guild here that helps with this. Though Im not really sure what to look for. Im going to go dig though the guilds again just in case I missed something.
Ok thanks. And I meant Guide not Guild... but I guess you already know that.
Been playing to much Europa...
6 Channel MP3
By RushMaster in forum AudioReplies: 9Last Post: 7th May 2014, 00:37 -
Split channels of a dual-channel MP3 without re-encoding
By zuja9 in forum AudioReplies: 11Last Post: 19th Aug 2012, 19:15 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 12:54 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 22:46 -
Multi-Channel sound on 4350 not working 100%, (ONLY 2-channel)
By THX-UltraII in forum AudioReplies: 1Last Post: 20th Feb 2009, 05:35
