I want to prepare a video clip to use as a motion menu (in Scenarist). What I want is to have a background texture with 5 thumbnmailed videos playing. In simple words, take the first 1 minute out of 5 separate video, reduce each one to around 120 x 90 and "embedd" them over the texture so that they all play at the same time side by side.
I can do all up to creating the 5 miniature clips. I can also use the final clip as a motion menu background in Scenarist.
What I can't figure out is how to combine the 5 miniature clips as thumbnails in a combo clip.
Anyone has done that? What tool? Anyone with a good suggestion ?
Results 1 to 11 of 11
The more I learn, the more I come to realize how little it is I know.
I have done this kind of thing with Premiere. if you have this goto www.wrigleyvideo.com for some great tutorials.
EDIT, that will get you the video you can encode to mpeg for the motion menu, how you add buttons etc in Scenarist I have no idea, but I guess you already know that bit. -
If you use Premiere, you'll use the Transform filter to acomplish that. You can also use the transform filter to animate the clips if you want.
I would also recomend that you use the Tittler in premiere to make the text in the menu. You'll have to make links to the text or thumbnails in your Authoring App.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
On the cheap...
I made a guide for doing this: https://www.videohelp.com/forum/userguides/164477.php
It uses Avisynth to do the work. You don't really need DVD-Lab as the guide shows.
However, the newest version of DVD-Lab will do this and produce an AVI for you. Probably the easyist "free trial" way to get a motion avi.
Also, in the guide there is a link to a discussion of at least 4 other ways to do this.
ToddI mean it in the nicest way. -
I like my Motion clips large so I use premiere and
make 320 x240 clips that consist of about 30 seconds of live video, but at
the end , I dissove on the timeline into a clip that ends where my little clip began..
That is to say, the clip internally dissolves and the new subclip ends with the very first frame on the timeline...
in this way my motion menu item appears to loop seamlessly!
I make an AVI but I'm using Sonic Foundry's ARCHITECT not scenerist -
Originally Posted by bugster
correct me if i am wrong.
thanks -
You can do this using AVISynth and frameserving. I've even seen scripts written by people that do exactly what you are doing. Search the Doom9 AVISynth Usage forum fot this script (from about a year or so ago).
Adobe After FX is also a tool that can do this (and with a very steep learning curve).ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Originally Posted by cinemode
I followed bugster's advice well back in November. Pretty amazing tutorials there. I've learned useful stuf about Premier.
But, in the meantime, I tried DVDLab. It has the ability to produce a motion menu like no other tool. Pretty fast and pretty accurate.
You can use DVDLab even just for creating the motion menu and use that clip in any other authoring program.The more I learn, the more I come to realize how little it is I know. -
Originally Posted by SaSiOpen WIDE for Chunky!!!
I too use DVD-Lab, but all my motion menus are created in Premiere. Premiere is much better suited to making motion menus. DVD-Lab allows you to make some really cool "Switched Menus", especially if you incorperate Motion menus into them. You can make some real cool effects with animation and invisible links.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
tape preparation and worries
By smartel in forum Newbie / General discussionsReplies: 1Last Post: 23rd Jan 2011, 10:47 -
Motion Menu Buttons
By lapetite_66 in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2009, 15:45 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
blank asset menu
By anakin1312 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Apr 2008, 05:21
