I have read that I can fool my DVD player into playing an SVCD clip just by changing the header using the VCD header trick.
I have also got a template to shrink a movie so it fits onto a single CD-R 80mins disc.
Is there a single disc SVCD template that I can use in TMPGEnc?
If I set the template to 100% of the disc space can I then use the header trick to allow it to be played on a DVD player that can be fooled with this trick?
Is there a problem if I create an SVCD MPEG2 file at 100% of the disc then use the VCD header trick that it will no longer fit on 1 disc?
Thanks much.
Fiiido
Results 1 to 1 of 1
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 20:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 17:21 -
DivX DVD Disc with Menu
By MI6 in forum Authoring (DVD)Replies: 3Last Post: 6th Jan 2009, 11:07 -
Tools for authoring several divx files in a disc
By Paco M. in forum Newbie / General discussionsReplies: 10Last Post: 13th Jun 2008, 17:33 -
Fix Bad Header/Bugs in an .avi divx file
By krisbee in forum LinuxReplies: 3Last Post: 24th Sep 2007, 08:54
