I see that SVCDtoDVD 1.5 can put 5 movies on 1 dvd. Question is does it compress the svcd to fit it on 1 dvd? Just wondering cause most of my movies i use are at least 1GB or more. Thanks guys. And Chrissyboy great work on the programs i use (S)VCDtoDVDMPG and then TMPGEnc to make menus and burn, its Flawless everytime. Thanks
MkstretchGuest
Can or Should?
No it can't, that's an erroneous statement. 5 movies will run a minimum of 7 1/2 hours. You aren't going to fit that on a DVD unles it's a VCD-DVD, even thin your out of bitrate to do it. You SVCD's should be 1.6 GB each, maybe 2.4 GB. Doing some quick math tells you you can get 2 movies, usually, per disk.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
unless he means 5 SVCD disks i.e 5x800MB
Guest
Thanks alot guys, Yeah i saw a post that said 5 movies on 1 dvd And knew it couldnt be true. Unless i misunderstood. Thanks again guys
TimoSGuest
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
edit Vob files in DVDR movies?
By SUPERIOR in forum Newbie / General discussionsReplies: 6Last Post: 12th Feb 2008, 12:12 -
Philips DVDR 3390 won't let me fast forward DivX movies
By guiri in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Sep 2007, 04:28
