Help,
I just purchased Pinnacle's InstantCopy and when I go to burn to a DVD-R I have the Source section on the left which lists my hard drive and DVD-R/RW drive. The destination section only lists my hard drive. I uncheck the box for the hard drive in the Destination section and then use browse to select my DVD-R/RW burner, but it still doesn't show in the Destination section, the hard drive is the only option available. For now I am copying the disc image to the hard drive and then using Nero to burn to a DVD-R. I would like to do everything from InstantCopy if I could, but don't know how to display my DVD burner in the Destination section.
Thanks in advance,
Bill
I think there are fix for your PC i heard some on Call for help talk about this. I do ot know how to fix it.
I had this problem my self I format my drive to fix the problem. Your drivers are out of wack. -
Thanks for the reply Spiderman. I don't think there's a problem w/the drivers. It's a brand new system right out of the box and other programs aren't having any problems recognizing the DVD burner. Maybe I'll uninstall InstantCopy and re-install it. If that doesn't help, maybe I'll contact Pinnacle, unless somebody has any other ideas.
Thanks,
Bill
Pinnacle AV/DV Card - problem with color
By leniwiec in forum Capturing and VCRReplies: 1Last Post: 2nd Jun 2010, 18:48 -
Pinnacle studio 14 problem with DVD export
By Alternator in forum Authoring (DVD)Replies: 1Last Post: 24th Feb 2010, 22:22 -
pinnacle 11 - sound capture problem
By lhg033 in forum Capturing and VCRReplies: 3Last Post: 1st May 2008, 20:56 -
Pinnacle studio program stability problem
By SearchQuality in forum Newbie / General discussionsReplies: 4Last Post: 14th Nov 2007, 21:06 -
Pinnacle DVD Problem?????
By Kmbfd558 in forum Authoring (DVD)Replies: 0Last Post: 15th Jul 2007, 09:31
