Can you please tell me what is a better cutting tool to cut mpgs than TMPGEnc?
Because with TMPGenc cutting doesnt work very well.
Please post your answers
you can use myflix or m1 edit which are the best mpeg cut and join tool in the world
If your source file has frame drops or not tmpgenc spec, tmpgenc will cut/merge incorrectly. I've used premiere6, vegas, mgi, ulead media, ulead video, etc., all have problems if your source is imperfect.
Frame serving was my solution. -
You can use VCD Cutter.
I didn't try it myself, but the other guys I work with in this kind of stuff, say that it's fantastic.
http://infotech.indiatimes.com/downloads/multimedia/players/vcdcutter.html -
for AVI , use virtual dub
for mpeg, use vcdcutter
bother those appz do clean cut, and real time previews
TMPEnc Authoring Works 4 Problem with input AC3 Audio (5.1 channels)!!!
By JackyWang in forum Authoring (DVD)Replies: 10Last Post: 22nd Jun 2011, 10:46 -
Problem with TMPEnc DVD Author 3
By ebadillab in forum Authoring (DVD)Replies: 11Last Post: 28th Jul 2009, 06:23 -
Progressive AVI encoding to DVD in TMPEnc - interlaced?
By Xoanon in forum Authoring (DVD)Replies: 16Last Post: 9th Jan 2009, 11:01 -
error in tmpenc
By php111 in forum Newbie / General discussionsReplies: 4Last Post: 4th Aug 2007, 07:56 -
Problem with TMPEnc
By Technophobe in forum Video ConversionReplies: 3Last Post: 28th Jul 2007, 16:44
