Hey,
Okay, im not exactly sure if this is right section to put this in, but ill try it n e ways
Okay, so I heard to sharpen up a picture, you should add filters to it. I also know that if u use too many filters ur gonna overkill the pic quality.
I was wondering if n e one recommends n e software w/ good filters or n e filters in general you have used to sharpen up the quality on a vid.
I must tell you that im doing this to analog video from a hi8 camera. I was thinking about using premiere's filters...i dunno...n e one recommend n e thing :P
THANX IN ADVANCE!
My take on this is that unless there's a reason you need to filter (to remove video noise, adjust video levels/chroma/hue, etc), then it's not really necessary to use filters and probably won't get you any better results. You can't make the video look much better than the source material. It's like the saying goes, "garbage in, garbage out".
Haali Media Splitter, LAV Filters, AV Splitter...How do these filters work?
By Moontrash in forum Software PlayingReplies: 3Last Post: 25th Feb 2012, 18:00 -
Need some filters or something
By salatoimikud in forum Video ConversionReplies: 1Last Post: 28th Nov 2011, 13:33 -
Megui Filters
By Ghost Buster in forum DVD RippingReplies: 1Last Post: 13th Nov 2011, 14:48 -
[Solved] Question about MPlayer filters in FFDShow and Mencoder filters
By BlooderButcher in forum Video ConversionReplies: 4Last Post: 24th Nov 2008, 11:32
