Any suggestions on getting the best quality still shot from either an avi or mpeg2 file. Output would be nice in either bmp, gif or tif.
I use Studio DV to capture from DV. DV camera also has jlip software that will capture a still, but I don't want to install it in case I have some problems with the firewire connection/capture facility. The jlip software sounds like it wants to use the serial port rather than the firewire.
Studio DV does allow me to grab a still from tape or captured video but the quality is poor. (although also related to my camera work..) I have tried output to bmp from TMPGEnc but setting ranges etc seems cumbersome & i get a huge number of bmp files that I have to sort through.(unable to comment on quality of this method)
Any suggestions would be apreciated on producing a quality still, preferably with some control over resolution, and if it accounts for the interlaced video...
thanks
mdez
I've found that the tmpenc method works best.
Set the range to the exact frame that you want and if you have interlacing (with movement in the frame) then de-interlacing will required.
Output to BMP.
Import your AVI or MPG into VirtualDub, find the frame you want, go up under the "Video" and choose "copy source frame to clipboard" then simply paste in Paint or a similar program. I use the Paperport program that came with my scanner, because I don't have Paint installed. Save to bmp
simple.
how to convert BMP to AVI ?
By monks19 in forum Video ConversionReplies: 2Last Post: 2nd Apr 2010, 15:08 -
DVDlabpro bmp subtitles to AVI
By Raynman in forum SubtitleReplies: 2Last Post: 28th Mar 2010, 06:04 -
BMP to AVI sequence
By max_e_mum in forum EditingReplies: 6Last Post: 17th Aug 2009, 05:57 -
Making an avi from jpg, bmp or png files
By cabs46 in forum Newbie / General discussionsReplies: 3Last Post: 14th Jan 2009, 06:14 -
Converted analog film movies to BMP/JPG: now to AVI and then DVD
By Wimpie44 in forum Newbie / General discussionsReplies: 13Last Post: 1st Jul 2007, 12:47
