    Oct 2003
    deep in Wonderland.
    I want to generate some timecode to use as a composite element in a project. It's only for effect though, so coolness is the priority - not accuracy. Vegas will generate rock-solid timecode for me, but the font that it uses is a) boring, and 2) hard-coded and unchangeable. My first thought was Avisynth, but AFAIK it won't do timecode. Anyone know of a program that will let me generate timecode with control over the font?
    Fight spammers ghetto kung-fu style! Join the Unsolicited Commandos!
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    can you do it with a subtitle program like Sub Station Alpha?
    superimpose them over a blank video file....
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
    Oct 2003
    deep in Wonderland.
    I think that would work for a static counter, but I want running timecode. Short of typing each number in manually, I can't figure out a way to do it in SSA. I haven't had much time to work with it, but there's no obvious "generate timecode" switch like I was hoping for...
    Apr 2002
    The State of Frustration
    Well, there is a digital stopwatch called Xnote Stopwatch. It is shareware, but you cannot change the font, but you can change the colors of the digits and background. Just capture it with WME9.Click here.
    Hello.
