i always can't view movies when their stream type is OpenDML AVI. i tried to play these movies in BSplayer, WMP, AVIPreview... it only works in VirtualDub (i know isn't a player but i tried anyway...).
video is Divx Pro 5.1 codec, audio is fraunhofer iis mpeg layer-3 codec. i've both codecs.
have anybody experience this? any solution?
i'm using a GeForce2 GTS 32MB using the latest v.52.16 driver (W2K). the movies were fine on another PC using a matrox G400.
below is the screenshot
Other than the video cards - what else is different between the 2 machines???
Does one have FAT32 file system and the other NTFS???
Generally you only mention openDML when you require files over 2GB or 4GB for DV files -
both are running W2K SP4... only major difference is my PC is a Celeron 525mhz while the PC with a matrox G400 is a P3 800mhz.
i mentioned OpenDML AVI b'cos it's the only common factor i can find among those movies displaying this problem. the other movies with other stream type doesn't display this problem.
white streaks, black streaks, comets, dropouts
By jmac698 in forum Capturing and VCRReplies: 6Last Post: 8th Mar 2012, 08:07 -
MP4 Stream Multiplexing Type Compatibility
By datbates in forum Video ConversionReplies: 0Last Post: 27th Jun 2011, 01:49 -
Stream type mismatch - 19023 with DVDit Pro 6 Redux
By jakewoodblues in forum Authoring (DVD)Replies: 0Last Post: 21st Apr 2010, 17:24 -
What are the benefits/disadavantages of Avi OpenDML?
By Anonymous5394 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Mar 2010, 09:58 -
Problem with TMPGEnc and AVI2 (OpenDML AVI)
By Firre in forum Video ConversionReplies: 1Last Post: 24th May 2008, 12:19
