Hello,
I am trying desperately to find info in the forums and FAQ, but I can't seen to get anywhere. Perhaps my seaching techniques are wrong. I dont know.
I have an LG-4040B burner, a Panasonic RV-32 standalone, and not enough knowledge
I basically have two questions.
1) When I am burning a double layered cd, what is the best program to use to have it split into two disks?
and
2) I found and read the 120 something reviews for my RV-32. In the end, I really am not sure of what to make of it all. Will the RV-32 play +R/+RW formats or not? I can get it to read –R/-RW and I haven’t tried + yet, mostly because I haven’t purchased any. But before I do, I want to know if it will play at all? What say you folks?
That’s it for now.
Thanks guys.
1. what is a doubled layered cd ?
2. the reports you read in the player reviews are peoples results -- some players (many) will read only certain types of formats and then only if certain media brands ..... so results will vary ... but generally speaking if you see a majority of people saying it will play something - it will play (perhaps not all brands though)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I apologize. By double layered, I mean a DVD-9, not DVD-5. Double sided I guess would be a better term.
Ditto on the double layered CD. Maybe a dvd? If so..dvd shrink
As far as the RV32, mine plays dvd+R, but my brothers cant. I dont know why, but thats how it goes sometimes when reading the forums, different methods of authoring, dif disc brands. Also, buy ONE +R disc, or buy a 5 pack of the R and +R, then even if one dont work, you can at least use the remaining ones to store data backups of your computer files.
Staxrip AAC Audio is causing brain to melt...
By The.King in forum AudioReplies: 3Last Post: 23rd Apr 2012, 15:47 -
Help for the non-functioning brain.....
By The.King in forum DVD RippingReplies: 1Last Post: 6th Jun 2010, 07:04 -
arrgg Racking my brain about x264 and Subs!
By nickolasj80 in forum Newbie / General discussionsReplies: 2Last Post: 28th Oct 2008, 15:24 -
Tivo (SVCD) to DVD - Brain Fart?
By fredfillis in forum Authoring (DVD)Replies: 0Last Post: 14th Sep 2008, 17:48 -
Something to hurt your brain
By guns1inger in forum Off topicReplies: 12Last Post: 22nd Aug 2008, 16:04
