  1. After ripping the files using Smart Ripper, using DVD2AVI & TMPGEnc (I used the VideoCD (NTSC)mcf template) I ended up with a perfect looking MPG file that plays perfect from start to finish on my PC. However, after buring it to CD-R when I put it into my DVD player it was nothing but pixels & the sounds had bleeps. Any thouhgts?
    Jul 2001
    Brazil
    What soft burn do you use? Do you use VCD template compliant?
    What's your DVD Player Unit model?
    Bye
  3. HEY MAN i THINK ITS BETTER USE DVD2MPG TO GET THE MPG FILES AND BURN IN NERO.....TRY TO USE CDRW OR CDR-DA MEDIA, OK?
  4. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>lafamar wrote: What soft burn do you use? Do you use VCD template compliant? What's your DVD Player Unit model?
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    I use Adaptec (I'm downloading Nero now) My DVD player is a Pioneer DV-525.
  5. I just burned the same file with Nero at 2x speed at it worker perfectly. The VCD played jus fine in my DVD player.
    I checked out the 1st copy I burned using Adaptec & noticed that all of the folders on the VCD except the MPEGav and the VCD folder contained no information. I used Nero and all of the info was in the folders. Any idea why?
  6. Could be your CDR media. I had problems with certain blanks. Apparently, my player only expects silver discs. I tried several brands with different results and I finally settled on TY blanks. They work perfectly.
    Darryl
    PS. http://www.getvcds.com reshipped my "seized" discs and they arrived this time without a hitch. I was very impressed with Lion King and Star Wars Trilogy.
  7. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    u should have got the pioneer 343...and u could have saved some money too
    only thing i hate about my pioneer 343 are the expensive ass cables i had to buy to ensure the best quality picture
