I burn a movie(Divx) from my computer to a dvd using TMGEnc and when I put it in my PS2 it freezes and shows me some menu and stops playing!!!BUT if I play it (the downloaded movie not the DVD)in windows media on my computer it is fine(no freezing).What is going on???
Also I burned MAtrix 2 and it stops playing audio 3 minutes into the movie on my DVD but it plays fine from the downloaded file on my computer??Are these related???
most likely your ps2's laser is going to shit or you're burning on shitty media
Welcome to the world! Downloaded DivX are crap. I'd say 9 out of then can't be converted to mpeg successfully without fixing up. Software AVI/DivX players are very forgiving and error tolerant, so the fact that you can view the DivX on your computer tells you nothing.
Use VirtualDub MP3 mod to scan for and remove bad frames and stuff. (There are guides for this on this site.) To boot, PS2 isn't the most compatible DVD player out there - try your effort out in a dedicated DVD player. (Again, not using a soft DVD player on your computer - they too tends to be more tolerant than their hardware counterpoint.)
/Mats
What causes computer freezing and slowness?
By Obamargarine in forum ComputerReplies: 13Last Post: 19th Apr 2009, 22:44 -
Computer Keeps Freezing
By Squid_uk in forum Newbie / General discussionsReplies: 14Last Post: 11th May 2008, 07:43 -
How to capture Real Player movie from site to computer?
By Chana1 in forum Video Streaming DownloadingReplies: 17Last Post: 14th Apr 2008, 08:10 -
CoreAVC freezing computer randomly
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 21st Dec 2007, 03:44 -
Computer Freezing up
By ruknabard in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2007, 17:52
