I'll be using an LG 4040b drive. Do I have to finalize a ram disk or not? Fi so, what the next step to make an easy yet attractive menu and chapter selection. MovieFactory is sooooo slooooooow!!
Thanks!
Ok, I realized in waiting from a response from someone that with a dvd-ram, the "disc setting" menu on the panny e80 doesn't even give an option for "finalize disk" as it does for a dvd-r. That answers that question.
Thanks for the response. -
more in depth details of yoour problem and what you want to achieve will usually elicit an answer.
One does not have to finalize a DVD-RAM disc when using Panasonic player/recorders.
If you wish to know how to use Ulead DVD MovieFactory 2 to extract the raw MPEG video/audio from a DVD-RAM disc...
1. Click the IMPORT DVD VIDEO button;
2. Browse to the location of your DVD-RAM computer drive and find the DVD_RTAV folder - highlight it - and click OK;
3. Follow the menu prompts.
As an alternative, one can sometimes use Microsoft Windows Explorer and to browse to the same DVD_RTAV folder and then copy the .VRO file from the folder to one's hard disk.
Then rename the .VRO extension to .MPG.
This method isn't always possible.
It depends on how the file was created.
Jerry Jones
http://www.jonesgroup.net
Tfr file from PC to DVD Recorder via RAM disk
By barry_w2 in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2010, 10:47 -
Disk Finalize
By arobertson1 in forum DVD & Blu-ray RecordersReplies: 28Last Post: 4th Sep 2008, 19:28 -
Playing DVD-RAM Video Disk On PC
By Rayvyn007 in forum Software PlayingReplies: 2Last Post: 23rd Jan 2008, 14:01 -
Burning to DVD RAM DISK and then play on your TV
By pmorris1 in forum Newbie / General discussionsReplies: 5Last Post: 25th Dec 2007, 19:15 -
How do I transfer Video from PC to DVD Recorder using a RAM Disk
By barry_w2 in forum Newbie / General discussionsReplies: 5Last Post: 17th Aug 2007, 14:14
